Enables the DHCP relay agent option (option 82).
Disabled.
After IP unicast routing has been configured, you can configure the switch to forward DHCP or BOOTP requests coming from clients on subnets being serviced by the switch and going to hosts on different subnets.
To configure the relay function, follow these steps:
Configure the DHCP relay agent option (option 82), using the following command:
configure bootprelay dhcp-agent information optionTo disable the DHCP relay agent option (option 82), use the following command: unconfigure bootprelay dhcp-agent information option
The following example configures the DHCP relay agent option:
This command was first available in ExtremeXOS 11.1.
